Hi i'm trying to host the ckeditor files on my content delivery network (CDN). Everything works fine but i have the following plugin. When i click OK i get an "Access Is Denied" error message. I'm assuming the "this._.editor.insertHtml" bit is causing the issue but i'm not sure how to fix it. Below is my plugin.js file:
I'd appreciate it if someone could help. Thanks
(function() {
CKEDITOR.plugins.add('imagemanager', {
requires : ['iframedialog'],
init : function(editor) {
var iframeWindow = null;
var me = this;
CKEDITOR.dialog.add('imagemanager_dialog', function() {
return {
title : 'Image Properties',
minWidth : 550,
minHeight : 320,
contents : [{
label : 'Insert Image',
expand : true,
elements : [{
type : 'iframe',
src : me.path + 'dialogs/imagemanager.html',
width : '100%',
height : 320,
onContentLoad : function() {
// Set the iframe window
iframeWindow = document.getElementById(this._.frameId).contentWindow;
// Try and get the current selected element
var selection = editor.getSelection();
var element = selection != null ? selection.getSelectedElement() : null;
// If an image is selected then set the appropriate values
if (element != null && element.getName() == 'img') {
iframeWindow.document.getElementById('url').value = element.getAttribute('src');
onOk : function() {
this._.editor.insertHtml('<img src="' + iframeWindow.document.getElementById('url').value + '" alt="" />');
editor.addCommand('imagemanager', new CKEDITOR.dialogCommand('imagemanager_dialog'));
editor.ui.addButton('ImageManager', {
command : 'imagemanager',
icon : this.path + 'images/icon.gif'
})();I'd appreciate it if someone could help. Thanks
Re: CKEditor CDN Plugin Issue
var hr = new CKEDITOR.dom.element('hr', editor.document );
editor.insertElement(hr);
Within my onOk function but this chucks a null reference exception. I'm almost at the point of giving up with CKEditor as the support is terrible.
The source of the horizontal rule plugin is quite easy to modify in order to perform some tests:
(function() { var horizontalruleCmd = { canUndo : false, // The undo snapshot will be handled by 'insertElement'. exec : function( editor ) { editor.insertElement( editor.document.createElement( 'hr' ) ); } }; var pluginName = 'horizontalrule'; // Register a plugin named "horizontalrule". CKEDITOR.plugins.add( pluginName, { init : function( editor ) { editor.addCommand( pluginName, horizontalruleCmd ); editor.ui.addButton( 'HorizontalRule', { label : editor.lang.horizontalrule, command : pluginName }); } }); })();Re: CKEditor CDN Plugin Issue
CKEDITOR.dialog.add('imagemanager_dialog', function() {Should have said:CKEDITOR.dialog.add('imagemanager_dialog', function(editor) {Now the editor instance gets passed in and you can say editor.insertHtml('...').
