I'm facing the problem. The bug only appears with IE but works fine with firefox.
You have to click on the first line to get the focus, but if you click anywhere else, nothing happens. If anyone has a trick to get over this bug, i m interested :]
Seems like this is still a problem - even in the latest CKEditor release (3.3).
I'm using IE 8 in compatibility mode and the CKEditor setting startupFocus is set to false.
As "bidulemachin" points out in the first reply, it happens when you click anywhere but the first line of the editor. If you click x2 times it gets focus, but that isn't optimal for our IE users/customers.
Anyone found a fix for this?
Edit: I investigated it further and I think is caused by the following settings: config.enterMode = CKEDITOR.ENTER_BR; - Can anyone confirm?
laped wrote:Edit: I investigated it further and I think is caused by the following settings: config.enterMode = CKEDITOR.ENTER_BR; - Can anyone confirm?
With IE 7, I removed the configuration option that you refer to in your post where config.enterMode = CKEDITOR.ENTER_BR and my problem of setting focus programatically on the editor was solved.
laped wrote:Seems like this is still a problem - even in the latest CKEditor release (3.3).
I still have the problem even after removing CKEDITOR.ENTER_BR;
Re: CKEditor 3.0 bug in IE with focus in textarea HELP
Thanks in advance
editor.on('click', function(ev)
CKEDITOR.instances.editor1.focus();
but it doesn't work (((
editor.on( 'contentDom', function() {
var doc = editor.document;
doc.on('click', function () {
doc.focus();
Seems to work with IE only if there s no text written before.
Post your ideas here, it could help
EDIT : There is the same bug with dialog boxes in " Paste " for example
http://dev.fckeditor.net/ticket/1659
I can NOT resovled it now .please help me
thanks....
