step 1: I use table.insertRow().insertCell() will create a "DayContent_2" textarea input then i use CKEDITOR.replace( 'DayContent_2' ) is work !
step 2: I table.deleteRow the step 1's "DayContent_2" textarea input !
step 3: I use table.insertRow().insertCell() create "DayContent_2" textarea input again, but CKEDITOR.replace( 'DayContent_2' ) isn't work ! it alert "undefined" but the "DayContent_2" textarea input is exist !
My English isn't very good and help me please , thanks a lot!
Create a "DayContent_X" textarea input javascript code
Delete a "DayContent_X" textarea input javascript code
dayday table html code
function createTextArea(){
var mytable = $("dayday");
var mycount = mytable.rows.length;
var row = mytable.insertRow();
var td1=row.insertCell();
td1.className='wbg';
var tmp1='<textarea name="DayContent_'+mycount+'" style="width:100%;" rows="8" id="DayContent_'+mycount+'" ></textarea>';
td1.innerHTML = tmp1;
try
CKEDITOR.replace( 'DayContent_'+mycount );
catch(e)
alert(e.description);
return true;
function deleteTextarea()
var myta=$("dayday");
var mycount = myta.rows.length;
if(myta.rows.length-1>1)
myta.deleteRow(mycount-1);
else
alert("The last one!");
return;
<table width="100%" border="0" cellpadding="2" cellspacing="1" bgcolor="#a0c5e9" id="dayday" name="dayday"> <tr> <td bgcolor="#FFFFFF"><input type="button" class="Button1" onclick="createTextArea()" value="insert" /> <input type="button" class="Button1" onclick="deleteTextarea()" value="delete" /></td> </tr> <tr> <td bgcolor="#FFFFFF"><textarea name="DayContent_1" rows="8" id="DayContent_1" style="width:100%;"></textarea></td> </tr> </table>
Re: About CKEDITOR.replace problem!
The right javascript code:
Thanks a lot!
