I'm looking for input on a couple issues I'm having with CKEditor for asp.net.
1. No idea how to integrate the SAVE button into a .net website using code behind.
2. When I toggle the visible attribute on the control it shows a text box with raw content to the user for a few seconds before it transitions to the editor.
3. Using an asp.net link button I can toggle the visible status of the editor but there's is some type of problem with it. On the page_load event I set it to visible = false and that works fine. I click a link button and toggle the editor to visible=true and the editor shows up. When I click the save button I toggle the editor back to visible = false. Sofar everything works. The next time I click the link button to toggle it back to visible = true I get 'null' is null or not an object.
Re: ASP.NET toggle panel with ckeditor causes null error
http://svn.ckeditor.com/CKEditor.NET/trunk/
Wiktor Walc
