I'm using CKEditor in my ASP.NET webforms application. I'm using CKEditor control to put it to my page:
But I'd like to get the editor's content length on client-side. I'm trying to do it this way:
Though it's not working because: "Uncaught TypeError: Cannot call method 'getData' of undefined"
So my question is. What am I doing wrong? And is it possible to get the CKEditor's length on client-side when using CKEditorControl?
<CKEditor:CKEditorControl ID="CKEditorControl" runat="server" />
CKEDITOR.instances['<%= CKEditorControl.ClientID %>'].getData().length;
Re: ASP CKEditorControl's content length on client-side
This works in api.html sample, but I don't know ASP.
You set the name of editor. Is it CKEditorControl.ClientID?
Hello guys,I am also having the same proglrm and I would like to know whether Have you solved the problem? I will appreciate if you can pm me some details.thank you.
$('#cke_<%= CKEditorControl.ClientID%>').find('iframe').first().contents().find('.cke_show_borders').first().html()But it's not. Any idea in this new approach?
$('#cke_<%= CKEditorControl.ClientID %> iframe').contents().find('body').html()I'm not sure now but I guess all the problems were because I was trying to get the data before the editor was loaded.
Doris
