Hi guys, to start off thanks for any help provided.
I'm having a small issue with 3.4, the CSS seems messed up. Now I've checked my CSS and all of my stuff that relates to input fields are referenced by classes. I've looked at the demo on the ckeditor website and it works fine without this error. I've viewed it in both IE and Firefox, newest version of both. The problem is, the text area's are expanding out side of their original areas on every element creation box. Please see the following image:
Since it works just fine on the Demo site, I assume it's my CSS conflicting with CKEditor's CSS, some how. I've tried looking through the CKEditor CSS, however it's not formatted very well and thus crazy hard to read or find anything out. So I need a little help. Can someone tell me what's going on or at least point me to the right css element in the css file that's applying to that?
And one last thing, this is the first version this has happened to me in. The last version I was using was: CKEditor 3.1 (revision 4891) I know it was a few updates behind, but I've been crazy busy this summer and haven't had time to keep up-to-date like I wanted. So this issue has had to happen between versions: CKEditor 3.1 (revision 4891) and CKEditor 3.4 (revision 5825).
Thanks again for any help!
Re: 3.4 Problem
label { float: left; clear: left; width: 45%; font-weight: bold; font-size: 15pt; }and it would appear the pop up menus for CKEditor use the label tags, that sucks I have A LOT. Hope this helps anyone else that may have the same issue!
Re: 3.4 Problem
editor.csskamafloat:none;
.cke_skin_kama * ....... {float:none;margin:0;......textearea
