I'm in the process of upgrading from FCK2 to CK3, and have found that when I click on some (most?) of the toolbar icons, I get Js errors like
c.push is not a function &
v.push is not a function
The results of my searching so far has found wonderful insights like
Has anyone experienced this, where should I be looking? Is there some reference to the plugins that isn't activated by default?
Toolbar icons that generate the errors are:
Image, flash, smileys, table, special chars, link, anchor, hidden field... etc
Things that do work are:
Bold, Italics, strike, Source, indents etc..
Thoughts?
Mister
if '.push' isn't a function, then 'c' isn't an array... which isn't very helpful.
Thoughts?
Mister
Re: .push is not a function... what? Sure it is.
It has nothing to do with CKEditor - or me (thank God). It's dreamweaver.
Dreamweaver took it upon itself to change the code. Opening the file in Textpad I get prompted...
So, I suppose it's combination between now being an asp file, and my using Dreamweaver.
Hope this helps someone else.
Mister
(Also, just noticed this is in the wrong forum, could one of the mod's please move this to the CKEditor Support section? Thanks.)
