I am new to ckeditor, i need to develop a plugin with a toolbar button, on click of the icon it should add text by default @ given position and not the cursor position.
For exemple 'Hello Sir,' should be always displayed @ the top left of my editor and not the cursor position.
Can u help me to have some insight how can i can achive this.
Thanks for ur help,
Diana
You can try your luck with
You can try your luck with the SDK. Or you can contact the guys at CKSource. They do custom development, although they're used to bigger, complicated projects.
Thanks for the reply , I
Thanks for the reply , I successfully integrated the above said using a toolbar icon using the SDK.
My next challenge is to insert word templates in ckeditor, ckeditor provide content templates any ideas how i can do the same for word templates
WYSIWYG editors only
WYSIWYG editors only approximate the look and styles of Word so you'll have to manually defined everything. Here's our documentation on how to configure styles (here's the link to the v3 documentation since this is the v3 forum section).
If you're referring to "Templates" templates, then here's the guide.
Thanks for the reply, i had
Thanks for the reply, i had the same burning issue too.
Error when add CFINDER into FCKEditor
hi! everybody I have problem with my site link mon ngon sai gon. i add module cfinder into FCKEDITOR but it error with content: no find XML, please help me! thanks
trieuquang198812, you look
trieuquang198812, you look like a link farmer but please remember that FCKeditor already includes a file manager!
How to create a Plugin in wordpress
Anyone can help me!!!
In the new management to
In the new management to creating the plugin, just go there and find the appropriate plugin needs to use his
