Hi!
I am using FCKeditor 2.5 and when I upload images, it always store them in webapp e.g. <webapp>/userprofiles/image folder. Is there any way we can store these images outside webapp? (as images gets lost when redeploy webapp)
Thanks in advance.
Thanks in advance.
Re: storing images outside webapp (fckeditor 2.5)
Thanks a lot Michael!!!
I have sorted this problem by having following properties in fckeditor.properties file:
#Needs to enable user actions (browsing, saving files, creating folders etc) first (for security reason this is disabled by default)
connector.userActionImpl=net.fckeditor.requestcycle.impl.EnabledUserAction
#Needs to change the connector imp from ContextConnector(default) to LocalConnector (connector serving all files from any local path)
connector.impl=net.fckeditor.connector.impl.LocalConnector
#Needs to change user path builder imp from ContextPathBuilder(default) to ServerRootPathBuilder
connector.userPathBuilderImpl=net.fckeditor.requestcycle.impl.ServerRootPathBuilder
#Finally, you can use any path on your server to save images or files
connector.userFilesPath=c:/data/iti/userfiles
connector.userFilesAbsolutePath=c:/data/iti/userfiles
This won't work, consult the docs for a 'why'!
Thanks for this useful information. I will try to find the answer from the documentation and will come back to this post.
Ok, got it Michael.
and connector.userFilesAbsolutePath is the path on server side and fckeditor will use this value to resolve the server-side location of resources.
connector.userFilesPath is the path on client side
THANKS!
This is the wrong thread. This is not ASP.
