Dear All,
I have just downloaded the FCK editor for .net and trying to integrate it. When i try to run the sample script , It gives me error page cannot be found. I am sure i am missing something in config file, but what i don't know.
Can anyone please help me with an example of web.config file for asp.net.
Many Thanks,
Many Thanks,
Re: FCK Installation For ASP.NET
Check out this post for answer : viewtopic.php?f=6&p=21784
There some setup steps you need to do:
1. unzip fckeditor 2.5 (for ASP.NET) to C:\Inetpub\wwwroot\fckeditor - download FCKeditor.Net from http://www.fckeditor.net/download
2. unzip fckeditor 2.5.1 to C:\Inetpub\wwwroot\fckeditor and okay for overwrite existing file(s) - download FCKeditor 2.5.1 (Latest Stable) from http://www.fckeditor.net/download
3. because when you created folder fckeditor, some users cannot access to read the files. So, right click at folder C:\Inetpub\wwwroot\fckeditor, select Properties, select Security Tab, add allowed access for ASPNET, INTERACTIVE, Everyone, IUSR_machinename, IWAM_machinename. Click Advance button, check Replace premission box, click Apply, click OK, click OK to close the properties.
Try the samples again. Hope this help.
I was succesful in inserting updating data in the database, but the strange and weired probably never across the problem was when i try to get the information back on some other aspx page, it shows all the HTML code on the page, rather than just showing the design and the text.
Please help.
Many Thanks,
<asp:TemplateField HeaderText="Note" ControlStyle-CssClass="Normal">
<ItemTemplate>
<%#DisplayHTML(Eval("Note"))%>
</ItemTemplate>
</asp:TemplateField>
Then with vb code behind
Function DisplayHTML(ByVal HTMLInput As String) As String
Return Server.HtmlDecode(HTMLInput).ToString()
End Function
Hope this help.
