Hi.
NOTE: IE problem (tested on winXP, IE 6.0, FCKeditor 2.1.1)
Also.. Read whole message before testing!
If I load the following text (end of message) into editor from a DB (PHP), then I'm not able to put cursor inside DIV using two mouse-clicks or more.
I have to click somewhere else inside the editor area before I'm able to place the cursor using the two mouse-click.
NOTE:
This is only reproducable if you FIRST try to place the cursor inside the DIV, if you click any other place in editor textarea, scrollbars or button area then this behaviour is not reproducable...
And you CANNOT just open a page with FCKeditor and then paste my code example inside the editor. You have to load the page and editor with this text in editor.
I would like to hear from someone else that they can reproduce this as well before I file a bug on this.
Anyone... ??
Code to test on below: (DO NOT PASTE INTO editor textarea (source)... that will not reproduce the error.):::
<div style="PADDING-RIGHT: 15px; PADDING-LEFT: 15px; PADDING-BOTTOM: 15px; WIDTH: 50%; COLOR: white; PADDING-TOP: 15px; BACKGROUND-COLOR: rgb(136,136,136)">Text here. Let see how it perform</div>
NOTE:
Anyone... ??
RE: Cursor problem in IE inside DIV in 2.1.1
I can easily reproduce in IE on demosite of 2.1.1 version.
If you paste my code exemple at end of message in source in FCKeditor (i tested on XP and IE 6.0), then turn editor into normal view (not source view), and then click outside the editor area in the page, and then now try to click twice on the div to edit the text... one are not able to edit the text... to be able to place cursor inside the DIV one have to, first click somewhere else in editor, outside the DIV.
Annoying bug and I hope there will come a patch soon to fix this.
Try to paste code below in the demo 2.1.1 in source view:
When can we expect a patch?
Re: Cursor problem in IE inside DIV in 2.1.1
any luck with this issue?
thanks,
adico
