I am using custom tags in FCK editor using ProtectedTags property. But when I switch back to source view, all these tags are being converted into lowercase.
I am using <SampleTag>. But when I switch back to source view, the tag is changed to <sampletag>.
Re: Case sensitive Tags in FCK Editor
All the tags are uppercased internally by IE, and the rest of the browsers I think that sometimes they respect them, but in order to get uniformity and following the XHTML guidelines all the tags are lowercased.
You might try to avoid the conversion done by FCKeditor, but you won't be able to fix IE.
